Mon, May 10, 2021 at 2:14:08 PM
Joined Sun, Nov 2, 2014 No rating This user is offline |
does not work
Sun, Jul 11, 2021 at 11:15:13 AM
Joined Mon, Aug 12, 2019 No rating This user is offline |
Hi anthonyderbish,
When downloaded a webpage opens with .pat text. Copy them . open note pad. Paste it and save with .pat(dot pat) extension
Then in Revit, Open material tab then surface pattern then model pattern-- New--load the pat.
Fri, Mar 11, 2022 at 7:37:58 PM
Joined Fri, Feb 6, 2015 No rating This user is offline |
Thank you so much!
Wed, Apr 13, 2022 at 12:08:54 PM
Joined Wed, Jul 9, 2008
Thanks!
Mon, May 30, 2022 at 3:14:44 PM
Joined Mon, Mar 27, 2017 No rating This user is offline |
THANK YOU!
Thu, Nov 3, 2022 at 10:01:32 PM
Joined Mon, Mar 15, 2021 No rating This user is offline |
thank you so much man, not only for the patter also for teach how to use it
Tue, Apr 2, 2024 at 2:27:58 AM
Joined Mon, Aug 5, 2013 No rating This user is offline |
Good. Thanks You.
Mon, Oct 21, 2024 at 8:09:56 PM
Joined Fri, Feb 13, 2015 No rating This user is offline |
Very useful.
Fri, Jan 31, 2025 at 12:10:26 PM
Joined Fri, Jan 31, 2025 No rating This user is offline |
Thank <a href="https://soundeffectgenerator.org">you</a>
Fri, Jan 31, 2025 at 12:10:47 PM
