58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Namo Benaras Dwar SL
478 Downloads
Nested door having 1 wooden door cum window frames & 4 door panel choice. Wooden frame can be single or double rebate. If you do'nt need ventilator- simply set the vent Ht to zero. Solid flush door can be conveted to stile n rail panel door by using mould thickness. Multi lite door can be 1V x1H to 10v x 4H lites of glass or other solid material. There is a extra frame(2ndry frame)  arroun multi lites, who's width can be zero if you do'nt need it. etc.  etc.  By adding param of Left or/& Right window with one can win frame also . No leaves are added in window frames to avoid the heavy size of the family.  Lallan Ji
RevitCity Division: Doors & Openings > Specialty
Uploaded By: Lallanji
Uploaded On: Sat, Dec 26, 2020
Original Creator: Contriver by L.J.Upadhyay.
Page generation time: 0.1908
