155 Users Online (153 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
W-Wide Flange With Spray Fireproofing (SFRM)
795 Downloads
Out of the box Revit Wide Flange family with spray on fireproofing added! After a long time of waiting to get to this, I finally did and decided to share because it seems unavailable anywhere else online. It appears to be a highly requested family throughout a lot of forums.
Parameters include, SOFP thickness, Visibility ON/OFF, & SOFP Realistic material. Family can be flexed and does not slow more complex framed structures significantly.
Visible in plan, 3D etc. Sections nicely as well. Great for wall firestopping & MEP coordination.
SOFP will adjust to any size beam selected and will also adjust to medium/fine detail level.
In order for this family to work properly, it’s imperative, the type catalog is located within the same folder as the family. I would suggest keeping them in the default directory together:
C:\ProgramData\Autodesk\RVT 2018\Libraries\US Imperial\Structural Framing\Steel
SOFP material JPG should be loaded into default materials directory as well:
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\3\Mats
Hope this is helpful and you enjoy for free! Family was created in RVT2018 but can be upgraded.
CSI Division: 05 12 00 Structural Steel Framing
RevitCity Division: Structural > Framing > Steel
Uploaded By: Walshman
Uploaded On: Fri, Apr 19, 2019
Original Creator: RPW
Page generation time: 0.2071
