28 Users Online (27 Members):
Reduced Pressure Detector Assemblies, Stainless Steel
304 Downloads
Series 994DCDA Reduced Pressure Detector Assemblies prevent the reverse flow of fire protection system substances from being pumped or siphoned into the potable water supply. The 994DCDA incorporates a meter to detect ground leaks and unauthorized illegal taps, greatly reducing annual water expenses. It consists of a stainless steel body, stainless steel internal parts, thermoplastic check valves and a bottom-mounted relief valve. Series 994DCDA is half the weight of competitive designs, and its short lay length makes installation and maintenance simple and easy. It is ideal for installation on fire protection systems. Check with local water authorities for installation requirements. Maximum Working Pressure: 175psi (12.06 bar) |
CSI Division: 22 11 00 Facility Water Distribution RevitCity Division: Plumbing > Distribution
Product Version: Revit MEP 2014 |
Uploaded By: iandevera
Uploaded On: Mon, Dec 31, 2018 Original Creator: Allied Technical Solutions / Watts Water Technology
Members: | 2066578 | Objects: | 23085 | Forum Posts: | 152257 | Job Listings: | 3 |
