45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
CIT CNC Chair or Table
457 Downloads
3 Stars from 2 Votes
About the Revit Family
This is a parametric ‘CNC’ table. The following are adjustable:
  • Top: rectangle or oval
  • Top: width and height (make these equal for a round or square top)
  • Top cross: sets the size of the cross in the top
  • Leg height and width
  • Leg cross brace: sets the depth of the brace at the top of the leg
  • Material thickness: this adjusts the size of the mortars and tension joint to accommodate different material thickness
How to use this on the CIT laser cutter
  1. Import the family and place in Revit view
  2. Adjust the sizes of the legs and top as desired – noting you’ll need both a Type A and Type B leg
  3. Adjust the material thickness to accommodate your chosen material
  4. Set the scale of the view to size of the final print, ie 1:50
  5. Export the view to DXF or Illustrator for adjusting line weights and printing
About
Designed by Andrew Remely - visit remely.com.au
Rights info - This work is licensed under a Creative Commons Attribution-Non Commercial-Share Alike 4.0 International License - for more information remely.com.au/copyright
CSI Division: 12 54 00 Hospitality Furniture
RevitCity Division: Furniture > Chairs > Stools
Uploaded By: Zippycat2001
Uploaded On: Tue, Jun 5, 2018
Original Creator: remely.com.au
Page generation time: 2.3413
