34 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Parametric Stirrup Bracket
3035 Downloads
This Stirrup Bracket is to be used at the top or bottom of a wood column. Two downloads are available. One with the stand-alone connector, and one with it attached to the bottom of a glulam column. The glulam column with integrated stirrup bracket is easier to use, but if you wish to place the bracket on the top of the column, or use in a different column family, the stirrup bracket family file should be used instead. All parameters are shared, so they can be used in schedules. The detail of the model has to be medium for the plates to appear, and fine for the bolts to appear.
See http://dylanbrowndesigns.com/resources/parametric-timber-connections-for-revit/ for an illustrative guide on how to use the connector.
This file was made in Revit 2018.
CSI Division: 05 00 00 Metals
RevitCity Division: Structural > Framing > Steel
Uploaded By: dtdylan
Uploaded On: Tue, Nov 7, 2017
Original Creator: Dylan Brown
Sun, Apr 11, 2021 at 8:20:13 AM
Robinjack
banned
Joined Mon, Mar 1, 2021
1 Stars from 1 Votes
I’d should consult with you here. Which isn’t something I usually do! I love reading a post which will make people think. Also, thanks for allowing me to comment! voyance tel avenir
Mon, May 31, 2021 at 9:42:00 AM
Robinjack
banned
I’m impressed, I have to admit. Really rarely do you encounter a weblog that’s both educative and entertaining, and without a doubt, you might have hit the nail around the head. Your notion is outstanding; the thing is a thing that insufficient consumers are speaking intelligently about. We’re happy we came across this within my hunt for some thing relating to this. open source ehs software
Thu, Aug 26, 2021 at 11:47:15 AM
Robinjack
banned
Early to bed and early to rise helps make a gentleman healthy, wealthy and sensible. food safety act and food hygiene regulations
Sun, Sep 12, 2021 at 11:49:56 AM
Robinjack
banned
Thanks for the wonderful as well as informative write-up We truly appreciate all the effort that proceeded to go in to the producing. car hauler transport services
Page generation time: 0.3237
