Valex SS Tubing BW Ball Valve
2921 Downloads
Staainless Steel, Tubing, Butt-Welded, Ball Valve.
Available Sizes: 1/4", 1/2", 3/4", 1", 1.5", 2", 2.5", 3", 4", & 6"
*Notes:
1)Change the Size by the "Diameter" parameter.
2) The "1412_hp-ball valve - Valex" PDF is the spec sheet / basis of design.
CSI Division: 43 Process Gas & Liquid Handling, Purification, & Storage Equipment
RevitCity Division: Mechanical > Distribution
Product Version: Revit MEP 2015
Uploaded By: Pikachu123
Uploaded On: Thu, Jul 16, 2015
Original Creator: Joe Mayo
Object Information
Diameter##PIPE_SIZE##INCHES
Type Comments##OTHER##
Radius##LENGTH##FEET
Overall Length or A1##LENGTH##FEET
Model##OTHER##
Manufacturer##OTHER##
Handle Thickness##LENGTH##FEET
Handle Length or E##LENGTH##FEET
Handle Height or D##LENGTH##FEET
URL##OTHER##
Description##OTHER##
Bolted Cover Radius##LENGTH##FEET
Bolted Cover Length##LENGTH##FEET
Bolted Cover Diameter##LENGTH##FEET
3.0in
GOOD 3in BALL VALVE!! (PC-1&PC-4)
0.125
0.9
HP Ball Valve
Valex
0.083333333
1.006666667
0.5025
P:\C-3265 NPTU\Families\Process\Basis of Design - Valves\SS 3in Ball Valve
SS BALL VALVE
0.25
0.45
0.5
0.25in
0.25
0.010416667
0.375
HP Ball Valve
Valex
0.020833333
0.366536458
0.180013021
SS BALL VALVE
0.020833333
0.1875
0.041666667
0.5in
0.5
0.020833333
0.416666667
HP Ball Valve
Valex
0.020833333
0.366536458
0.180013021
SS BALL VALVE
0.041666667
0.208333333
0.083333333
0.75in
0.75
0.03125
0.4375
HP Ball Valve
Valex
0.020833333
0.42578125
0.193359375
SS BALL VALVE
0.0625
0.21875
0.125
1.0in
0.041666667
0.458333333
HP Ball Valve
Valex
0.03125
0.470703125
0.243489583
SS BALL VALVE
0.083333333
0.229166667
0.166666667
1.5in
1.5
0.0625
0.583333333
HP Ball Valve
Valex
0.03125
0.643229167
0.313476563
SS BALL VALVE
0.125
0.291666667
0.25
2.0in
0.083333333
0.666666667
HP Ball Valve
Valex
0.03125
0.643229167
0.343424479
SS BALL VALVE
0.166666667
0.333333333
0.333333333
2.5in
2.5
0.104166667
0.791666667
HP Ball Valve
Valex
0.03125
1.006510417
0.473307292
SS BALL VALVE
0.208333333
0.395833333
0.416666667
4in
0.166666667
1.029296875
HP Ball Valve
Valex
0.0625
1.293294271
0.586588542
SS BALL VALVE
0.333333333
0.514648438
0.666666667
6in
0.25
1.416666667
HP Ball Valve - (*Note: 6in Handle Can Be From 18""-36"")
Valex
0.0625
1.5
0.883463542
SS BALL VALVE
0.5
0.708333333
Page generation time: 0.5611
