35 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Nested SL Door-3 with SP by L.J.Upadhyay
1780 Downloads
Nested door having 2 door frames & 4 door panel choice. Wooden frame can be single or double rebate. If you do'nt need ventilator- simply set the vent Ht to zero. Solid flush door can be conveted to stile n rail panel door by using mould thickness. Multi lite door can be 1V x1H to 10v x 4H lites of glass or other solid material. There is a extra frame(2ndry frame)  arroun multi lites, who's width can be zero if you do'nt need it by setting Stile panel offse and rail panel offset to zero. Each & every elements have seperate material params. etc.  etc.  Lallan Ji
Most params are Shared Parameters.
RevitCity Division: Doors & Openings
Uploaded By: Lallanji
Uploaded On: Tue, May 12, 2015
Original Creator: ContriverBIM by Lallan Ji
Page generation time: 0.2198
