30 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Stair Arrow
2122 Downloads
Stair Arrow
It is a Line based detail component rather than a symbol. I made it this way so the overall length would stay the same if the scale changed. The text will change with the view scale and in the instance properties there is an input for a scale to change the arrow and circle sizes. (I preprogramed the typical scales so you can see how they work) There are 3 types of arrow heads and the text can be controlled separately.
  Edit* the scale things does not work atm I will tryand fix it later.
Hope it helps,
smh
CSI Division: 96 30 00 Symbols
RevitCity Division: Detail Components
Uploaded By: ScubaMan
Uploaded On: Thu, Jan 15, 2015
Original Creator: smh
Page generation time: 0.2630
