Concrete Cobogó (Hollow block)
9236 Downloads
Regular hollow concrete block (Cobogó, in portuguese). It's fully parametric (material, height, width, sill hight, quantities) which can all be summarized on tables. Can be controlled via Lines or Columns parameters or by its height and width, knowing that it must be a multiple off 10cm.
Its version is Revit 2014 |
CSI Division: 08 50 00 Windows RevitCity Division: Windows > Miscellaneous
Product Version: Revit Architecture 2013 |
Uploaded By: daversd
Uploaded On: Sat, Oct 19, 2013 Original Creator: David Dória
Tue, Apr 12, 2016 at 7:17:56 AM
Joined Tue, Aug 7, 2012
não abre no 2016, infelizmente
Mon, Oct 17, 2016 at 11:27:43 AM
Joined Thu, Mar 25, 2010
Abriu no 2016 Sim!!
Thu, Nov 24, 2016 at 6:16:32 AM
Joined Mon, Oct 3, 2016
Perfeito, Obrigado !
espero que não seja tão pesado feito um bloco que eu criei
Tue, May 16, 2017 at 2:34:08 PM
Joined Mon, May 15, 2017 No rating This user is offline |
Não consigo abrir no 2017
Mon, Jun 5, 2017 at 6:46:55 PM
Joined Tue, May 2, 2017
Para funcionar tem que aplicar como se fosse uma JANELA...
Tue, Dec 11, 2018 at 2:47:08 PM
Joined Fri, Aug 22, 2014 No rating This user is offline |
Sousa Não abre no revit 2014.
Members: | 2121216 | Objects: | 23208 | Forum Posts: | 152302 | Job Listings: | 3 |
