103 Users Online (102 Members):
3Form Panel & Suspension System (Panel)
7695 Downloads
These files are based on 3Form Panels and 3Form Suspend Solutions Hardware. These files are meant to be used together and placed into the Project Environment. The Panel can be customized in width and height (Note that 3Form panels are typically 4'-0" wide by 8'-0" high maximum) and is placed by the centerline in height to coordinate with the suspension system parameters. The hardware suspension system has adjustments for overall height and the panel centerline height to move the clips up and down. The clips can be switched from center clips to end clips and the bottom attachment can be changed from floor mounted to wall mounted as well. NOTE: THIS DOWNLOAD ONLY DOWNLOADS THE PANEL. THE SUSPENSION SYSTEM IS A SEPARATE DOWNLOAD. |
CSI Division: 10 22 00 Partitions RevitCity Division: Uncategorized
Product Version: Revit Architecture 2013 |
Uploaded By: jroh
Uploaded On: Fri, Aug 9, 2013 Original Creator: Jeremy Roh
Tue, Apr 1, 2014 at 11:28:55 PM
Joined Wed, Apr 7, 2010
would be nice if there was provision of a link to the suspension system. what a tease.... very nice.
Members: | 2057620 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
