Fri, Jul 13, 2012 at 11:38:45 AM
Joined Fri, Nov 12, 2010 No rating This user is offline |
How can I get the hatch to not be upside down?
Thu, Jul 19, 2012 at 3:02:02 AM
Joined Thu, Sep 22, 2011 No rating This user is offline |
The Hatch pattern is too dense... is there a quick fix without going through and increasing every number?
Cheers
Tue, Jun 20, 2017 at 1:58:05 PM
Joined Thu, Apr 4, 2013 No rating This user is offline |
I had to add a line in the .pat file to make this a model pattern. Replace the first line with:
*Fishscale shingles,Fishscale shingle pattern-reversed for use in Revit;%TYPE=MODEL
Thu, Sep 28, 2017 at 3:01:41 PM
Joined Thu, Sep 28, 2017 No rating This user is offline |
anybody figure out how to make this pattern display right side up? it imports with the shingles upside down - thansk!
Thu, Mar 8, 2018 at 2:24:46 PM
Joined Wed, Nov 25, 2009 No rating This user is offline |
Just grab one of the vertical lines and rotate it 180 degrees.
Tue, May 26, 2020 at 1:59:46 PM
Joined Thu, Mar 24, 2016 No rating This user is offline |
did anyone figure out how to make this pattern not upside down? the comment about grabbing a line and rotating it 180 degress will not work unless it is a model line pattern. I also attempted change of first line of code to the text of what another suggested but it still does not register as model line in revit.
Thu, Feb 18, 2021 at 3:32:23 PM
Joined Mon, May 13, 2019 No rating This user is offline |
how to save as .pat file?
Thu, Sep 9, 2021 at 10:46:27 AM
I AM ALSO AWAITING AN ANSWER ON HOW TO MAKE THE PATTERN NOT UPSIDE DOWN
Mon, Oct 24, 2022 at 5:00:33 PM
Joined Mon, Jan 11, 2021 No rating This user is offline |
PUT IN SECOND LINE
;%TYPE=MODEL
IMPORT AS MODEL HATCH AND 12 SCALE
