Wed, Feb 29, 2012 at 9:20:55 AM
Joined Mon, Feb 13, 2012
just be careful when u increase the number of pannels that you also increase the opening width
Wed, Feb 29, 2012 at 3:46:10 PM
Joined Thu, Jun 25, 2009
What do you mean, RAACdrafting? Do you think I should have had the opening width driven by the number of panels and their width?
Thu, Mar 1, 2012 at 7:30:22 AM
it would help otherwise as you increase the pannel numbers it just space them out inside the existing opening.
Thu, Mar 1, 2012 at 3:43:43 PM
Thanks for the comment but I strongly disagree with that. In my opinion we come across situations where we need the number of panels to be defined by the total width of the door much more often than the other way around.
Fri, Mar 2, 2012 at 7:46:43 AM
well that may be so, but your bound to run into problems with to much door coverage not enough opening or vise versa is all i was thinking about i like it eitherway
Wed, May 20, 2015 at 5:20:59 PM
Joined Mon, Apr 6, 2015 No rating This user is offline |
Hi, is it possible to adjust the height and how do I add extra panels? Thanks for the upload!
