59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Spanish Roof Tiles 3
13556 Downloads
4 Stars from 9 Votes
CSI Division: 07 40 00 Roofing & Siding Panels
Uploaded By: chrisakohl
Uploaded On: Wed, Oct 19, 2011
Original Creator: chrisakohl
Wed, Oct 19, 2011 at 2:14:28 PM
chrisakohl
Joined Sun, May 8, 2011
5 Stars from 5 Votes
You need to download all three files. Draw a model line from bottom to top on your roof face and array it at 9" spacing. Then trim each line to correct length, and use the second file (line based) for any tiling row that needs three or more tiles. Just select the lines.
Use the third file for the spine tiles (same process just draw a line on the spine of the roof).
Use the first file for any rows that are two tiles or less in length. If it needs two, check "2nd tile". If not, leave unchecked.
Materials parametric, be warned it will make your model pretty heavy.
Tue, Oct 25, 2011 at 7:45:57 PM
DiMauro99
Joined Thu, Aug 18, 2011
Im on revit 2010 and the file does not load. Says on later version, unable to open. Could you explain how you created the tiles and how exactly you would add them on the roof please Smile Thank you.
Thu, Jun 13, 2013 at 5:02:14 AM
axdadmin
Joined Thu, Apr 19, 2012
save it in lower version.. unable to open
Thu, Jan 15, 2015 at 12:04:54 PM
Ansem202
Joined Thu, Mar 21, 2013
Small shortcut:
Create a roof material with 9" parallel lines at 90 degrees. Needs to me model not drafting. The clay tiles will snap to these lines instead of having to create model lines.
Fri, Feb 5, 2016 at 6:30:14 PM
payam2000
Joined Tue, May 12, 2009
This looks great! Have you tried using "sloped Glazing" for your roof? that way, you can assign these files to automatically become your tiles (panels) and your corner pieces (mulions)
Wed, Oct 26, 2016 at 6:49:46 AM
afyarritu
Joined Wed, Feb 12, 2014
@payam How can I do that??? I cannot choose this model as a sloped glazing panel!
Sat, Jul 15, 2017 at 5:52:23 PM
allanzamora
Joined Fri, Apr 17, 2015
Thank you. These tiles are the best!
Sat, May 25, 2019 at 9:39:30 AM
euronimous
Joined Sat, Oct 16, 2010
Thank you, man, this is very helpful!
Page generation time: 0.8206
