Wed, Jul 6, 2011 at 8:57:46 AM
Joined Sat, Sep 26, 2009 No rating This user is offline |
Fantastic family.. The way the n of panels are driven is really interesting
Fri, Nov 11, 2011 at 7:43:31 PM
Joined Sat, May 29, 2010 No rating This user is offline |
I cannot load the family into revit 2012
Thu, Feb 9, 2012 at 8:36:52 PM
Joined Thu, Jun 25, 2009
Good stuff, thanks for making the curtain wall version of my one!!!
Thu, Mar 15, 2012 at 5:48:38 PM
Joined Mon, Jan 7, 2008 No rating This user is offline |
wont work on 2012 for me either
Tue, Apr 3, 2012 at 11:56:20 AM
Joined Fri, Jul 8, 2011 No rating This user is offline |
me neither
Fri, Apr 6, 2012 at 3:09:22 PM
Joined Wed, Dec 1, 2010 No rating This user is offline |
excellent, thanks! it works like a charm (just treat like a typical curtain door) !!
Thu, Jun 7, 2012 at 8:11:03 AM
Joined Tue, Mar 15, 2011
excelent, but if there is some way to choose to be shown us shuted?
Wed, Aug 22, 2012 at 5:09:34 AM
Joined Tue, Apr 7, 2009
works perfectly on 2012versionThanks
Sun, Sep 16, 2012 at 11:11:10 PM
Joined Fri, Apr 27, 2012
I can´t open the family =(
Wed, Oct 17, 2012 at 6:19:16 AM
Joined Thu, Mar 20, 2008
i cant import it into project
any ideas why?
Tue, Nov 27, 2012 at 12:00:21 AM
Joined Wed, Nov 23, 2005 No rating This user is offline |
It works fine in 2013 as well. When you load it, look for it under the "Curtain Panels" Section of the project browser. I created a new curtain wall type with no horizontal grid pattern and a vertical grid pattern fixed distance of the entire opening. I Then spacified the "cutain wall folding walls" panel as my cutain panel and created the wall in the project. Not sure if this is the best way but it sure worked nice.
Thu, May 16, 2013 at 6:50:39 AM
Joined Sun, May 3, 2009 No rating This user is offline |
really really nice :-)
thank you
Sun, Jun 30, 2013 at 10:00:39 AM
#13
Joined Sat, Jun 29, 2013 No rating This user is offline |
thank you
Wed, Nov 6, 2013 at 1:55:22 AM
#14
Joined Thu, Oct 31, 2013 No rating This user is offline |
it works but only shut one way.. need to improve or Make it right side and left side
Wed, Nov 6, 2013 at 1:59:52 AM
#15
Solution: Go to Edit type. There is option for left panel and right panel
Mon, Mar 24, 2014 at 10:32:00 PM
#16
Joined Sun, May 27, 2012 No rating This user is offline |
wont work for me, 2013 version
Mon, Jun 9, 2014 at 11:06:55 AM
#17
Joined Wed, Jun 29, 2011 No rating This user is offline |
how do you turn the left vs. righ panels on? this option is greyed out and only the first 3 right panels are turned on in my project.
Mon, Jun 9, 2014 at 11:09:50 AM
#18
Nevermind. I figured it out.
Thu, Oct 30, 2014 at 8:29:23 PM
#19
Joined Sun, Oct 12, 2014 No rating This user is offline |
I cant change the material of the panel frames. one panel fram changes and the next one doesnt.
Tue, Dec 30, 2014 at 7:47:54 PM
#20
Joined Tue, Aug 3, 2010 No rating This user is offline |
Its great family, I ennjoyed a lot Using it, so great you share this kind of work, fully parametric Thanks a lot.
Mon, Jan 12, 2015 at 2:58:23 AM
#21
Joined Mon, Oct 27, 2014
HI, IAM NOT ABLE TO LOAD IT INTO MY REVIT MODEL. I HAVE REVIT 2014
Fri, Jun 5, 2015 at 5:02:25 AM
#22
Joined Sun, Aug 12, 2012 No rating This user is offline |
Can load it into project in revit 2015...
Sun, Nov 1, 2015 at 9:49:37 PM
#23
Joined Tue, Nov 18, 2014 No rating This user is offline |
i can see it under curtain panels in project browser but how do you get it from there into the wall you want to put it in?
Sun, Jan 31, 2016 at 7:40:12 AM
#24
Joined Thu, May 1, 2014
Same as MELANIEMILLER67 I see it loaded in the project browser (Revit 2015) but how do you actually use it ?
Bit of help would be greatly appreciated... Thanks :-)
Wed, May 4, 2016 at 10:20:44 AM
#25
Joined Sun, Feb 5, 2012
You have to first select your curtain panel and then just change it to the door.
Wed, May 4, 2016 at 10:20:46 AM
#26
Wed, Sep 7, 2016 at 8:35:53 AM
#27
Joined Wed, Apr 29, 2015 No rating This user is offline |
aamzing family!!
Tue, Dec 20, 2016 at 9:23:01 AM
#28
Joined Wed, Dec 14, 2016 No rating This user is offline |
I love this item
Thu, Jan 5, 2017 at 5:57:18 AM
#29
Joined Thu, Jan 5, 2017 No rating This user is offline |
Amazing family, great job AndyHarle. Works excellently in 2016. Although...
One issue I am having is setting panel number to anything greater than 5. When you make it 6+ (I need 7), the family appropriately shrinks the panel width, but DOES NOT increase the number from 5. Looking in the family, allowance has only been made for 5. I am no expert in delving into others parametrics, anyone got any advise how to modify?
Cheers,
Adam
Wed, Mar 8, 2017 at 6:05:09 AM
#30
Joined Wed, Jun 18, 2008
5* for this component.LOVE IT! PERFECT!Thanks a million
Fri, Mar 31, 2017 at 8:43:05 AM
#31
Joined Mon, Nov 11, 2013 No rating This user is offline |
@AAHAS
You can not create more than 5 Panels with this family. The panel "creation" ist not fully parametric.
Overall very usefull! Thanks for it!
Fri, Mar 31, 2017 at 8:43:49 AM
#32
@AAHAS
Tue, Dec 5, 2017 at 9:06:19 AM
#33
Joined Wed, May 20, 2015 No rating This user is offline |
this is GOLD. Thank you!
Mon, Mar 5, 2018 at 9:12:06 PM
#34
Joined Fri, Jul 26, 2013 No rating This user is offline |
thank you good job
Tue, Mar 13, 2018 at 9:08:14 AM
#35
Joined Mon, Jul 4, 2016 No rating This user is offline |
Ths family is amazing!! Thank you so much for sharing it
Thu, Jun 21, 2018 at 2:58:03 PM
#36
Joined Tue, May 10, 2016 No rating This user is offline |
for some reason I only seem to have one window with material and the one next to it a frame with a transparant material. Cant seem to make the material visible.
Mon, Aug 13, 2018 at 12:35:26 AM
#37
Joined Sat, Feb 19, 2005
WOW!
Mon, Sep 17, 2018 at 12:59:49 PM
#38
Joined Tue, Oct 10, 2017 No rating This user is offline |
cannot import to 2018....
Mon, Sep 17, 2018 at 3:58:11 PM
#39
Joined Wed, Jul 6, 2016 No rating This user is offline |
This is amazing thanks.
Thu, Nov 8, 2018 at 10:35:10 AM
#40
Joined Mon, Jun 26, 2017 No rating This user is offline |
Thank!!!
Tue, Nov 13, 2018 at 9:05:22 AM
#41
Joined Wed, Nov 18, 2015 No rating This user is offline |
Absolutely perfect... no frills, is a curtain wall panel, easy to modify parameters... spot on friendo.
Life saver
Sat, Dec 8, 2018 at 11:39:15 AM
#42
Joined Sat, Dec 8, 2018 No rating This user is offline |
cannot import to rvt18..
Wed, Jan 2, 2019 at 12:27:09 PM
#43
Joined Fri, Jan 8, 2016 No rating This user is offline |
This is exactly what I needed; I looked for so long and here it is! Thank you! Very well made family.
Wed, Feb 20, 2019 at 12:34:05 PM
#44
Joined Fri, Feb 15, 2019 No rating This user is offline |
Is there an option to show the doors closed?
Wed, Feb 20, 2019 at 12:34:19 PM
#45
#46
#47
Thu, Nov 21, 2019 at 12:43:59 PM
#48
Joined Tue, Apr 24, 2018 No rating This user is offline |
Thanks! This door worked great! I was able to have 3 panels on the right and 4 on the left. If you want to show the doors closed, just change the open angle (under dimensions) to 0.
Mon, Aug 30, 2021 at 4:50:28 PM
#49
Joined Thu, Aug 10, 2006 No rating This user is offline |
Excellent many thanks will be a huge help for a visualisation for my client. Excellent work.
Mon, Aug 30, 2021 at 4:50:30 PM
#50
Sat, Jun 10, 2023 at 12:57:51 AM
#51
Joined Mon, Aug 22, 2022 No rating This user is offline |
Very nice . Thanks a lots
#52
Wed, Nov 1, 2023 at 9:20:23 PM
#53
Joined Wed, Nov 1, 2023 No rating This user is offline |
Mr. Rubio was here
#54
Mr. Rubio was here
Wed, Nov 1, 2023 at 9:20:31 PM
#55
Mr. Rubio was here.
Wed, Nov 1, 2023 at 9:20:32 PM
#56
Mr. Rubio was here
Wed, Nov 1, 2023 at 9:20:39 PM
#57
Mr. Rubio was here
Wed, Nov 1, 2023 at 9:20:44 PM
#58
Mr. Rubio was here
Wed, Nov 1, 2023 at 9:21:01 PM
#59
Mr. Rubio was here
Wed, Nov 1, 2023 at 9:21:03 PM
#60
Mr. Rubio was here
Wed, Nov 1, 2023 at 9:21:04 PM
#61
Mr. Rubio was here
Wed, Nov 1, 2023 at 9:21:41 PM
#62
Mr. Rubio was here
