Tuscan Column - TRUE Classical Proportions!
22462 Downloads
![3.5 Stars from 4 Votes](/images/stars_3.5.gif)
![](images/spacer.gif) | ![Tuscan Column - TRUE Classical Proportions!](object_docs/11225.jpg)
This is a Tuscan column family with TRUE classical proportions according to the 16th century Italian architect Giacomo Barozzi da Vignola, which scale according to column height. If desired, there is also a checkbox to change height independent of the column diameter and other diameter-driven parameters. This also goes along with the Tuscan Column Base family. This was created in Revit Architecture 2012. |
CSI Division: 10 74 00 Manufactured Exterior Specialties RevitCity Division: Architectural Columns > Round
Product Version: Revit Architecture 2012 |
Uploaded By: PatrickS
Uploaded On: Mon, May 23, 2011 Original Creator: Patrick Smith, www.aercpllc.com
Mon, Jan 23, 2012 at 10:07:33 AM
Joined Sat, Jun 18, 2005 No rating This user is offline |
AMAZING! Perfect proportions....At least someone still cares as much as I do about classical proportions. Any Plans on doing the Doric, Ionic, or Corinthian?
Wed, May 23, 2012 at 10:50:24 AM
Joined Wed, Feb 9, 2005
![3 Stars from 2 Votes](/images/stars_3.gif) This user is offline |
None at this time, since those are not just simple revolve solids. It would be massively time consuming to figure out how to model those, and then to get them to scale would be an even larger undertaking. No plans on spending the time on that. I have just resorted to using the 3D CAD imported columns here on Revit City and scaling them to different heights as needed.
Mon, Apr 22, 2013 at 9:22:34 AM
Scaling Ionic and Corinthian columns have now been uploaded!
Thu, Mar 27, 2014 at 10:09:22 PM
Joined Sun, Mar 24, 2013 No rating This user is offline |
love it!
Wed, Jun 11, 2014 at 4:09:18 PM
![MBarkitek Avatar](user_avatar/562495.jpg)
Joined Thu, Mar 6, 2014 No rating This user is offline |
Great job!
Wed, Apr 8, 2015 at 12:09:50 PM
Joined Mon, Dec 10, 2007 No rating This user is offline |
Exactly what I needed, great flexibility, great proportions. Thank you Patrick!
Wed, Aug 12, 2015 at 10:37:43 AM
Joined Wed, Aug 12, 2015 No rating This user is offline |
Hey Patrick,
Is there anyway i could get the Greek Doric Column...similar to that used in the Parthenon on Acropolis....the scaling one.
Thanks man.
Mon, Feb 5, 2018 at 1:41:29 AM
Joined Thu, Aug 3, 2017 No rating This user is offline |
AMAZING JOB
Wed, Apr 4, 2018 at 1:26:20 PM
Joined Thu, Mar 25, 2010 No rating This user is offline |
thanks, works great. The best classical column for revit I have found
Fri, Nov 2, 2018 at 2:14:49 PM
Joined Fri, Nov 2, 2018 No rating This user is offline |
Thanks!
Members: | 2017013 | Objects: | 22944 | Forum Posts: | 152210 | Job Listings: | 3 |
