Tue, Mar 29, 2011 at 1:50:23 PM
Joined Tue, Mar 29, 2011 No rating This user is offline |
how do i copy this into my project? it says its read only
Tue, Apr 12, 2011 at 12:02:55 PM
Joined Mon, Mar 24, 2008 No rating This user is offline |
load it into your project as a family and if already loaded insert it as a component
Wed, May 4, 2011 at 11:01:15 AM
Joined Mon, Oct 25, 2010
![5 Stars from 2 Votes](/images/stars_5.gif) This user is offline |
Bst elevator on revitcity
Sun, May 8, 2011 at 6:57:01 PM
Joined Sat, May 22, 2010 No rating This user is offline |
great elevator..fully parametric.
Fri, Jul 1, 2011 at 6:24:12 PM
Joined Fri, Jul 1, 2011 No rating This user is offline |
very good elevator, easy to modify but unfortunatelly only up to the 10 stop which is not enough .. .![Sad](/images/smiles/sadley.gif)
Tue, Sep 27, 2011 at 3:27:36 PM
Joined Fri, Jan 16, 2009 No rating This user is offline |
It would be nicer if the parameters actually made some sense but thanks!!!
Mon, Oct 31, 2011 at 9:48:07 AM
Joined Fri, Feb 20, 2009 No rating This user is offline |
How do you change the number of stops? and which parameter is the distance between stops?
Sat, Jan 28, 2012 at 7:46:24 PM
Joined Sat, Jan 28, 2012 No rating This user is offline |
Just had a question - did anyone have issues with the doors not cutting into the walls at all the levels?
Mon, Jan 30, 2012 at 10:22:20 AM
Joined Mon, Jan 30, 2012 No rating This user is offline |
How do you offset door? Looking for a R or L opening door.
Thu, Mar 1, 2012 at 9:24:17 AM
Joined Wed, Mar 26, 2008
![5 Stars from 1 Votes](/images/stars_5.gif) This user is offline |
If you hit the spacebar before you place the elevator in a wall, it will mirror it so the door opens on the other side. And you can change the number of stops in the properties bar, under Construction. It is named, "Elevator Number of Stops"
Great Elevator!!!
Thu, Apr 19, 2012 at 11:30:31 AM
Joined Wed, May 4, 2011 No rating This user is offline |
Hello - how do you reduce the number of stops I cant find the property under construction - I am using Revit Arch 2011
Sun, Apr 22, 2012 at 4:37:51 AM
Joined Sun, Apr 22, 2012 No rating This user is offline |
To reduce the number of stops select the elevator and then look at the property menu. Under "Construction" you will see "_Elevator Number of Stops." Change this value to a number between 2 and 10. Also make sure your distances are set correctly under this same section. Generally they should match your ceiling height.
Tue, May 1, 2012 at 1:04:03 PM
#13
Joined Fri, Mar 18, 2011 No rating This user is offline |
I keep getting a message that says:
Instance(s) of Service / Hospital_4000 not cutting anything.
what do I do?
Tue, May 1, 2012 at 1:19:46 PM
#14
what do I do?
Thu, Sep 13, 2012 at 12:10:04 PM
#15
Joined Tue, Apr 7, 2009
![4.5 Stars from 6 Votes](/images/stars_4.5.gif) This user is offline |
complex, but well done ![Winking](/images/smiles/wink.gif)
Nice job!
Tue, Oct 23, 2012 at 9:53:57 AM
#16
Joined Tue, Feb 8, 2011 No rating This user is offline |
Great job! Thank you very much ! : ))))
Mon, Nov 12, 2012 at 4:52:02 AM
#17
Joined Mon, Sep 27, 2010 No rating This user is offline |
Nice elevator, the best so far. But how do you increase the number of stops?... say up to 20 or more???
Wed, Jan 30, 2013 at 5:26:05 PM
#18
Joined Thu, Jan 27, 2005
![1 Stars from 1 Votes](/images/stars_1.gif) This user is offline |
LEVEL THREE Door not cutting out wall properly.
Tue, May 21, 2013 at 4:07:46 PM
#19
Joined Wed, Aug 10, 2011 No rating This user is offline |
how could I flip the entry side to opposite side of elevator on the first floor?
Wed, May 22, 2013 at 5:10:55 PM
#20
Joined Wed, May 22, 2013 No rating This user is offline |
how could I flip the entry side to opposite side of elevator?
Sun, Mar 9, 2014 at 4:24:51 PM
#21
Joined Sun, Mar 9, 2014 No rating This user is offline |
I am trying to incorporate this elevator into my college project without any success. Once i load the family it just doesnt appear, when I try to include it for a second time it just says "do you want to overwrite it again or overwrite with parameters". tried both options and still remains to be unseen. Any help? Student in urgent need of help!
Thu, Apr 3, 2014 at 6:52:49 PM
#22
Joined Tue, Nov 26, 2013 No rating This user is offline |
By far the best elevator I have ever used thanks! But any idea how to extend the columns on the top of the elevator so they can match the story height to meet my exisiting structural framing?
Tue, Jul 29, 2014 at 7:41:31 PM
#23
Joined Wed, Apr 16, 2014 No rating This user is offline |
Cant seem to find how to change the amount of levels the elevator stops at. I only want 3 but there are no ways to change it under the construction title in the settings. Can someone please help? ![Smile](/images/smiles/smile.gif)
Wed, Aug 26, 2015 at 4:24:27 PM
#24
Joined Tue, Oct 7, 2014 No rating This user is offline |
I wonder how long you took to do this... BIG THANK YOU
Tue, Sep 15, 2015 at 1:06:03 AM
#25
Joined Mon, Aug 31, 2015 No rating This user is offline |
this has 10 stops i only need 4 if i change the stops to 4 i get an error and some of the doors are not cutting thru walls.
how to fix?
Wed, Apr 13, 2016 at 3:08:06 PM
#26
Joined Sun, May 11, 2014 No rating This user is offline |
If you get a message saying its not cutting anything it means you neeed to attach it to a wall
Tue, May 16, 2017 at 1:52:53 PM
#27
Joined Tue, May 9, 2017 No rating This user is offline |
awesome elevator thank you
Wed, Aug 23, 2017 at 7:19:25 AM
#28
![aaurnab Avatar](user_avatar/468525.jpg)
Joined Mon, Jun 3, 2013
![2.5 Stars from 3 Votes](/images/stars_2.5.gif) This user is offline |
how to change Nos of Stops to 15 or more...
Sun, Dec 17, 2017 at 3:24:44 PM
#29
![Ankhaa Avatar](user_avatar/578085.jpg)
Joined Tue, Apr 8, 2014 No rating This user is offline |
How do I extend the stops, say more than 30 or 40? anyone having the same issue?
Tue, Oct 30, 2018 at 10:00:26 PM
#30
Joined Wed, Sep 27, 2017 No rating This user is offline |
brilliant! well done and thank you very much
Mon, May 11, 2020 at 1:43:16 PM
#31
Joined Tue, May 16, 2006 No rating This user is offline |
Very nice elevator, how can i centralize the access door?
Mon, Jun 21, 2021 at 9:50:50 AM
#32
Joined Thu, Jan 14, 2016 No rating This user is offline |
Awesome elevator. How do you offset door? Looking for a R or L opening door.
i see comment #9 but not a response, thanks, Hal
#33
Tue, Jun 22, 2021 at 12:32:46 PM
#34
I really appreciate the kind words...If you want to know the truth I have not been on this site in a very long time...I was actually surprised this was still on the site and even more surprised to see the amount of downloads...I did this family back in 2008 back when no manufacturer had a parametric elevator...I reloaded the family and unforturnately I did not make it to have a R or L opening...Just the different sizes...I have not used this elevator since manufacturers provide their own BIM products now...I will say that I think this elevator is more graphically pleasing than the manufacturers...
Mon, Mar 28, 2022 at 9:00:35 AM
#35
Joined Mon, Mar 28, 2022 No rating This user is offline |
omg omg; I searched so long for a Hospital elevator and this is awesome! the doors and everything, thank you
