112 Users Online (111 Members):
Forums >> General Discussion >> Wishlist >> Same Parameter Different Familiy
I am using Revit MEP 2008 but this idea could work with all Revit apps. There should be a way to multiple edit a specific parameter across similar family types. eg. Insulation for ductwork cannot be added across the whole duct system, bends & junctions are treated seperatley meaning you need to select similar for each family type. If a common parameter exists in multiple families it would be good if you had the option to select this as a multiple to update.
You could apply the desired parameter as a shared parameter. This will allow you to select multiple categories and apply the parameter to all families of a certain category on the project. Go to File-->Shared Parameters to set up your parameter. To add it to a project you will go to Settings-->Project Parameters and select the category(s) you want to add the parameter to.
Explode Families? |
Thu, Jul 10, 2008 at 8:28:00 AM
Structural Tie |
Mon, Aug 19, 2013 at 11:27:33 AM
Type Cataloge by Familiy Type |
Fri, May 22, 2009 at 12:20:35 PM
Multiple Nested Category Familiy Tags |
Wed, Jan 30, 2013 at 4:02:47 PM
Count |
Mon, Oct 17, 2005 at 12:31:49 AM
Members: | 2030694 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
