140 Users Online (139 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Exterior Bearing Walls?
Tue, Jan 22, 2008 at 7:33:36 AM | Exterior Bearing Walls?
RPonx
Is there a way to classify exterior walls as load bearing?  I am trying to show portions of the exterior wall as bearing walls for my structural plans.  I cannot find the location to change this setting.  I found the setting for the interior walls.
Thanks
Tue, Jan 22, 2008 at 8:46:40 AM | Exterior Bearing Walls?
aandr001
4.5 Stars: 6 Votes
The place to find the setting should be the same as for the interior walls.  Right click on the wall, select "Element Properties", scroll down to the structural catagory and select bearing.  Good luck.
Bearing vs. Non-bearing walls
Wed, Oct 10, 2012 at 3:04:30 PM
Before I Start Copy/Monitor
Thu, Sep 6, 2012 at 10:19:47 AM
exterior finsh below zero
Sun, Apr 11, 2010 at 10:13:36 AM
Plan region/bearing walls
Mon, Jan 21, 2008 at 12:14:19 AM
Floor Truss Endpoint on Bearing Wall
Thu, Jan 16, 2014 at 9:52:23 AM
Page generation time: 0.7204
