102 Users Online (101 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Door Family Cut Plan
Mon, Jan 21, 2008 at 11:56:02 AM | Door Family Cut Plan
JHanby
3.5 Stars: 3 Votes
The door I made cuts correctly in the family (right side in pdf) but when inserted into the model (the left side) the cut doesn't show the mullions like it does in the family. You can only see them when you hover over the door.  I checked  and both cut planes are set the same.  What am I doing wrong?  Using Revit 9.1
Mon, Jan 21, 2008 at 11:56:46 AM | Door Family Cut Plan
JHanby
3.5 Stars: 3 Votes
oops forgot to attach pdf.  sorry.
Jill
Tue, Jan 22, 2008 at 3:03:44 AM | Door Family Cut Plan
dianajohn
Try raising or lowering the view range in the family to be in the middle of the mullions that you have drawn.
Hope this works
John A
Tue, Jan 22, 2008 at 6:07:42 AM | Door Family Cut Plan
JHanby
3.5 Stars: 3 Votes
I tried that before I posted and it didn't work. No of my previous doors have that problem, only the last two that I have made.  They are big storefront frames that I modeled into a door family, could that have anything to do with it?  I would think all the doors would work the same regardless.
Tue, Jan 22, 2008 at 10:05:50 AM | Door Family Cut Plan
JHanby
3.5 Stars: 3 Votes
Just figured this out.  The family was set to wireframe instead of hidden line.
DOOR CUT PROBLEM IN PLAN
Thu, May 4, 2006 at 7:34:59 AM
Door family - opening covers door leaf
Fri, Sep 30, 2016 at 4:36:46 AM
Cut plane for doors and widows different from plan!!
Wed, Oct 18, 2006 at 8:41:37 AM
Door family elements showing in plans
Sun, May 1, 2011 at 9:29:23 PM
Door knob misplaced in plan view
Fri, Feb 22, 2013 at 8:12:53 AM
Page generation time: 1.7244
