Forums >> Revit Building >> Technical Support >> Column Grid Line Weight
14 Posts No Rating |
I'm currently working on a parking garage in Revit Architecture 2008 and I have come to a issue that I can't solve! I'm adding column grid and I want to adjust the line weight of the grid itself. I have adjusted the head of the column grid to be a 4, but I have no selection in the "Visibility Graphics>Object Styles" to adjust the line weight of the grid. Any help? Thanks!
Mine might be set up differently than yours, but I can change that line-weight by clicking on a grid line, hitting properties, clicking Edit/New... and changing the Line Weight parameter in the family type parameters. Hope that helps.
That worked! Thanks... Don't you think that all the line weight controls should be this way?
0 Posts No Rating |
Hi
Is it possible to change Grid Head circle thickness?
so that the grid line will be lighter and the bubble circle will be a bit darker
0 Posts No Rating |
yeah, sorry, i got it
it is from Manage, Annotation , Grid head line thickness
Column Grid line missing when printing |
Mon, Nov 23, 2009 at 11:20:50 AM
Column to Grid |
Tue, Sep 8, 2009 at 4:09:31 PM
Ceiling grid line weight |
Wed, Aug 8, 2018 at 4:33:13 PM
Column Grid Text |
Tue, Dec 11, 2007 at 9:33:36 AM
column grid visibility |
Wed, Nov 15, 2006 at 3:43:13 PM
Members: | 2097942 | Objects: | 23164 | Forum Posts: | 152288 | Job Listings: | 3 |
