79 Users Online (78 Members):
Forums >> Revit Building >> Technical Support >> hatch pattern modification???
![3 Stars: 1 Votes](/images/stars_3.gif) |
morning, all... seems this should be very simple to do, but i can't figure out how to... i want to create a model hatch pattern (revit arch 0 for 8x24 cmu. i wm trying to use 8x16 cmu as base, and copy/modify, but it doesn't seem to give any options for this... any ideas??? thanks in advance! i see that hatchkit website, but it says that the free version creates watermarks on the hatches, which i can't have on construction issue dwgs...
Hatches are just text files which you can edit. Type this in a simple txt file with notepad and this should work. (the 12 replaced the normal 8 for a 8x16) *CMU_8x24 Running, CMU: 8x24 Running bond 0, 0,0, 0,89 0, 0,0, 8,12, 8,-8 Edited on: Mon, Jan 21, 2008 at 11:16:50 AM
Edited on: Mon, Jan 21, 2008 at 11:17:20 AM
wwhub... that did it! rock o! thanks for the help, i appreciate it.
Exporting hatch pattern |
Thu, Sep 18, 2014 at 6:27:35 PM
hatch pattern not printing |
Mon, May 8, 2017 at 12:56:51 PM
Hatch pattern |
Tue, Jan 13, 2009 at 10:23:47 AM
Hatch 22- Curve Pattern |
Wed, May 30, 2018 at 4:07:07 PM
custom hatch pattern without hatch editor |
Wed, Jan 28, 2015 at 8:46:58 PM
Members: | 2017201 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
