105 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Stone walls
Fri, Mar 4, 2005 at 5:45:50 AM | Stone walls
Will9000
4 Stars: 5 Votes
There are no stone walls in the families, can anyone help, i need it for a 3d image if poss and i dont know how to create one?
Fri, Mar 4, 2005 at 9:29:07 AM | RE: Stone walls
fazerneil
4 Stars: 5 Votes
If it is stone wall on a building. Duplicate any wall from revit (cavity/single skin wall style as required) If by 3d you mean rendering, there are stone materials in standard revit materials library, if no use, either take your own photo image of a similar wall and install as a jpeg into your stone material or pull a jpeg image off a web site. Assign your new render material to the wall leaf material. If you want a country freestanding wall. Draw it as normal and then edit profile to give it a nonregular top. Render as above.
Mon, Mar 7, 2005 at 6:10:12 AM | RE: Stone walls
Will9000
4 Stars: 5 Votes
Hey Thanks!! Easy when you know how!! Still learning Cheers
Stone Walls, Stone Veneer, etc
Fri, Oct 6, 2006 at 8:21:59 AM
Stone walls
Sat, Jan 12, 2013 at 5:40:43 AM
fill patterns and stone walls
Fri, Aug 18, 2006 at 8:54:33 AM
Stone Wall
Tue, Aug 20, 2013 at 3:55:34 PM
Stone Capstone...
Sun, Feb 11, 2007 at 10:31:04 AM
Page generation time: 2.5178
