53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revision numbers
Fri, Jan 18, 2008 at 3:26:17 AM | Revision numbers
tim123
4 Stars: 19 Votes
I do not seem able to set my sheets up so that a revision number can be applied only to the applicable sheet.  It will only change hte revision number globally (ie to all the drawings).  Is there a way round this, without doing it manually.  Any help would be apppreciated.
Tue, Jan 22, 2008 at 8:35:03 PM | Revision numbers
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Go to Settings-->Revisions and toggle "By Sheet" instead of "By Project". This will let the revision numbers be controled separatly for each sheet.
Wed, Jan 23, 2008 at 2:44:19 AM | Revision numbers
tim123
4 Stars: 19 Votes
Thanks for that - I did try that, but it only seems to aplly to the revision cloud numbering on the sheets.  When I issue drawings I don't want to issue the whole set, only the ones with a revision.  A revision number change to each sheet suggest that each drawing has changed.
Wed, Jan 23, 2008 at 10:01:14 AM | Revision numbers
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I think I understand your issue now. What we do if we need to issue a revised sheet is place a revision cloud and tag around the sheet number. We would do this on the Drawing Sheet view. This way a revision entry will show up in the box and by clouding the sheet number it signifies that either the sheet was added or there were to many revisions to cloud and tag them seperately.
Wed, Jan 23, 2008 at 10:12:53 AM | Revision numbers
tim123
4 Stars: 19 Votes
Thanks - I will try that - the AutoCAD contingent at our work are pouncing on this issue.  Perhaps a manual overide means that it is no more difficult than in AutoCAD.
revision leters instead of numbers
Mon, Mar 6, 2006 at 7:15:55 AM
Revision schedule showing revision sequence numbers with empty descriptions
Thu, Feb 28, 2013 at 3:46:03 PM
Scheduling revision nunbers
Tue, Oct 13, 2009 at 9:57:04 AM
Revision Schedule not updating
Tue, Aug 28, 2012 at 7:59:18 AM
Revision Numbering
Wed, Dec 12, 2012 at 1:11:15 PM
Page generation time: 0.2643
