64 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> delete dimension style?
Is there any way to manually delete a dimension style from the project browser? I tried to purge the style out, but it seems to be used somewhere, so it wouldn't purge out. It is not supposed to be in the file at all, so I just want to make it go away.
You should be able to acheive this by Creating a dimension on the style you want to remove and right click on the dimension and click "Select all Instances". You can then apply all selected items to another dimstyle or delete the items. This should propagate through all of your views. I just did a very simple test and it worked. I am not sure about dimensions contained within groups though. Just a thought.
Delete a dimension type |
Mon, Oct 17, 2005 at 3:06:39 AM
CREATING DIMENSION STYLE w-embedded text? |
Thu, Jul 24, 2008 at 1:42:38 PM
Prefix in dimension style |
Thu, Dec 16, 2010 at 9:15:11 AM
Can not delete Dimension |
Thu, May 3, 2018 at 2:51:36 PM
What controls Dimension style of inserted Labels? |
Tue, Aug 6, 2013 at 12:37:46 PM
Members: | 2017161 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
