49 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> control of hidden objects
26 Posts No Rating |
Is there a way of grouping a set of objects of different types, and then easily toggling their visibility on and off? I've been using hide/isolate as a means of creating 'cut-away' views, which I guess is probably not what the command was intended for. It would be nice to be able to form a selection set of say, a roof, ceiling, walls, doors and windows, and then be able to turn all of that on and off to facilitate looking inside the model.
![JAMESHGRIMES Avatar](user_avatar/17328.jpg)
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
I would look into using a Scope Box. This allows you to define a 3D box crop region. You can then drag the extents to adjust the location of the boundary. Nothing outside the boundary is visible. What I usually do is to create a "Working 3D view" so I can manipulate visibility without messing with any of my other 3d view.
Hidden Objects in Sheet views |
Fri, Jun 13, 2008 at 12:10:26 PM
MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE |
Fri, Aug 11, 2006 at 1:18:15 PM
Centreline, hidden line control display colour |
Mon, May 14, 2018 at 7:26:01 AM
Reveal Hidden Objects |
Wed, Mar 16, 2011 at 4:06:25 PM
Bring back Hidden objects in 2008 |
Mon, Nov 12, 2007 at 10:26:50 AM
Members: | 2022285 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
