50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Stairs - viewing from floor above.
1 Posts No Rating |
I have a two level building, I have created a stair going from level on to level two. Then I edited the second floor slab to include a hole for the stair to come through and be visible on the second floor plan. However, I can't see the stair on the second floor plan. I have checked in section and elevation and the stair is in the right place and located right underneath the hole in the second floor slab. How can I get the stair to show up on the seond floor plan? I am using Revit Architecture 2008.
Edited on: Tue, Jan 15, 2008 at 8:13:50 AM
Check the view depth of your view. If you don't want to change that to the floor below, you can use a plan region with the view depth set correctly.
Also check your Visibility/Graphics settings to make sure that stairs are visible in your plan.
Ruth Rau Main Street Architecture, P.C. |
Revit's collor fill hides floor slab floor slab doesnt hide stairs anymore |
Thu, Feb 8, 2007 at 2:08:28 PM
Floor Plan View Range - Viewing a half storey |
Thu, Jul 12, 2007 at 3:32:23 PM
Stairs to second floor showing full stair |
Thu, Jun 4, 2015 at 9:44:02 AM
12
3D Transparent Viewing |
Mon, Jun 9, 2008 at 5:45:00 PM
2 sets of stairs, 1 landing, 1 cutback. possible? |
Sun, Mar 1, 2009 at 3:28:10 AM
Members: | 2017233 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
