130 Users Online (129 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> stairs up arrow
Thu, Mar 3, 2005 at 4:28:52 PM | stairs up arrow
aabrmn
My stairs are not showing the up arrow. checking or not in the stair instance properties has no effect. Does anybody experienced the same issue? What am I missing? Thanks.
Thu, Mar 3, 2005 at 5:29:42 PM | RE: stairs up arrow
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yeah the old up arrow's on stairs have always been a bit buggy... The tend to only work correctly when you've using the run command to draw the sketch. For anything custom you'd be best off drawing the arrow in afterwards or using a detail component arrow. Hopefully in the next release! HTH.
Fri, Mar 4, 2005 at 9:35:35 AM | RE: stairs up arrow
aabrmn
Thanks Mr Spot, I guess for consistency I will probably have to redraw my stairs (!). A little warning from revit about this issue while executing the stair command would have been nice...
Wed, Oct 12, 2011 at 1:39:26 PM | stairs up arrow
mfgarrod
six years later.....  i think i'm encountering the same problem with Revit 2011.  is there, at this time, a better remedy than an annotated arrow?
stairs
Thu, Nov 29, 2007 at 10:59:31 AM
stair UP / DN arrow
Tue, Jun 19, 2012 at 6:54:20 PM
Stair Arrow visible only in one view?
Thu, Oct 11, 2012 at 2:19:25 PM
Stair Issue
Mon, May 11, 2009 at 1:22:10 PM
Stairs going in the wrong direction
Sun, Feb 15, 2009 at 5:41:35 PM
Page generation time: 1.6539
