86 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Line Styles
Tue, Jan 6, 2004 at 11:19:11 PM | Line Styles
cdsdraft
Is there a way (Formula)To make a line with a dash, space, W, space for a representation of waterlines ,etc. on the site plan? Or what are others doing to represent utilities
Wed, Jan 7, 2004 at 8:46:25 AM | RE: Line Styles
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
For now, the only options available are dashes and solids for custom line types. Hopefully they'll make a way to make any type of custom line soon.
Hiroshi Jacobs
The Catholic University of America
Sat, Jan 10, 2004 at 7:55:52 PM | RE: Line Styles
FreeRangeMonkey
You can use the repeating detail tool in 6.0 to do this.
Thu, Jan 15, 2004 at 7:14:47 PM | RE: Line Styles
Priority
If there is a particular line styles you�re currently using in AutoCAD and you'd like to us it in Revit also. 1. Draw the line in a cad drawing. 2. And save the file. 3. Call it LINETYPE.dwg 4. Open a session of Revit and import that saved file. Now delete it. This new line style appears under SETTINGS_LINEPATTERNS. Unfortunately the aforementioned linestyle will not work because of the character "W" embedded in the linestyle. This method can be used when making a company default template with certain linestyles preloaded. Keep in mind the most commonly used linestyle are come with Revit.
Removing Line Styles
Mon, May 8, 2017 at 2:21:05 PM
Associating Line styles with patterns
Tue, Sep 18, 2012 at 11:30:06 AM
Deleting Line Styles
Tue, Aug 5, 2014 at 2:57:30 PM
Line styles
Sun, Jun 3, 2018 at 8:27:35 AM
Complex line styles
Thu, Mar 16, 2017 at 7:37:13 AM
Page generation time: 0.6821
