102 Users Online (101 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Help needed to Align a Filled Region to a "family" (Deck Span Direction)
Fri, Jan 11, 2008 at 3:11:01 PM | Help needed to Align a Filled Region to a "family" (Deck Span Direction)
jameshands
I'm modifying the Span Direction Annotation to look more to our office standards. I've got exactly what I need except the correct visual rotation of the filled region. I tried using regular linework instead of a region, but that created other problems...
I need the filled region to rotate with the deck span direction and I'm running out of time on this project. Anybody got a quick fix?
I also tried editing the cut fill pattern to "Align with element", but without success.
Thanks
james
Edited on: Fri, Jan 11, 2008 at 3:41:19 PM
Fri, Jan 11, 2008 at 4:07:23 PM | Help needed to Align a Filled Region to a "family" (Deck Span Direction)
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Hey James,
Please let me know if this is what were looking for or if I misunderstood you.
Brett
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Mon, Jan 14, 2008 at 12:38:57 PM | Help needed to Align a Filled Region to a "family" (Deck Span Direction)
jameshands
Yes!  But... The deck symbol is running in the wrong direction.  We need it turned 90 degrees to match the directino of the deck ribs.
Also, I rotated the slab direction (just for the hey of it) on the plans and the symbol went all wonky.  Something's still not jiving somewhere...
I know this must seem like a silly request but I have a "circular" building where the deck direction changes every 5 degrees and the boss wants it shown properly.  I'll have to note every section manually for now.
Thanks
Extending Deck Span Direction Symbol
Mon, Jun 1, 2009 at 12:44:52 PM
"Solid white" filled region that prints in black
Mon, Aug 1, 2005 at 8:47:28 AM
Detail Component / Filled Region
Wed, Aug 19, 2009 at 10:57:45 AM
1 1/2" Metal Deck Visibility
Tue, May 13, 2008 at 11:40:34 PM
Metal decks spanning in different directions on the same level
Mon, Nov 9, 2009 at 9:10:56 AM
Page generation time: 1.3628
