Forums >> Revit Building >> Technical Support >> If statements
Wed, Mar 2, 2005 at 11:59:17 PM | If statements
shaun_kiwi
5 Stars: 2 Votes
Does anyone know if under family types in the formula section how you use a yes / no type in an IIF statement?
Thu, Mar 3, 2005 at 1:46:16 AM | RE: If statements
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
There is no need to use IF statements to define yes/no parameters... If the formula is true then its yes if its false then its no. Say you have a visibilty yes/no parameter setup for a mullion. You can have a formula in your yes/no parameter stating width>1200... There visibility will be yes if this statement is true... HTH.
Tue, Feb 12, 2013 at 4:42:38 PM | If statements
RandyBrown
Mr. Spot...thanks for all your posts you are the man
Question....If I have a sheet index conditional formatting question
I figured out how to do a graphic if it is yes or no, but what I really need is if Issued for Review=Yes then use graphic IFR_Yes (R)and if =No then nothing but and here's the catch I might be issuing that sheet for Construction in turn want my Issued for Construction=Yes to place a IFC_Yes graphic (X) and if it =No then nothing..
This is what I used for the graphic when it was just issued or not if((ISSUED_FOR_REVIEW_02_13_13), Graphic Yes, "")
Can you help
Tue, Feb 12, 2013 at 5:26:06 PM | If statements
TKennedy
4 Stars: 8 Votes
Try this:
if(Issued For Review, "R", if(Issued For construction, "X", ""))
I didn't test that, but it should work (swap out your parameter names as needed). Also, I think IFR should override IFC in that example (if both are checked then it will display R).
Conditional statements in families.
Wed, May 14, 2008 at 4:27:34 PM
IF statements (fields and filters within quantities)
Fri, Jan 22, 2010 at 8:14:07 AM
Spreadsheet Math and "IF" Statements
Mon, Jul 1, 2013 at 2:22:08 PM
IF STATEMENTS
Wed, Dec 2, 2015 at 10:21:14 AM
11
Revit 10?
Tue, Jan 23, 2007 at 2:19:21 PM
Page generation time: 0.1902
