38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall Section Dims
Fri, Jan 11, 2008 at 9:51:42 AM | Wall Section Dims
jonblaze451
1 Stars: 1 Votes
R-ARC 08
I am dimensioning my exterior wall thicknesses, but I have some trouble when I dimension my curved walls.  I have tabbed in order to select the wall faces, but a curved wall seems to be stubborn.  Any ideas?
Mon, Jan 14, 2008 at 3:05:17 PM | Wall Section Dims
LIZARD2806
3.5 Stars: 7 Votes
A dimension to a curved wall in section is somewhat impractical.  As the dimension constantly changes, you would want a dimension in section to read "varies".  At the very least, it should read a dimension, followedd by "varies".  If you want to still dimension it the latter way, I would recommend adding a reference plane.  When adding the plane, you should be able to grab the end point of the line that represents the top of the wall, then make a vertical reference plane.  You can then dimension to the reference plane.  HTH
**Using Revit Architecture 2009, 2011, and 2012**
DIMENSIONS
Fri, Jan 23, 2004 at 1:58:08 PM
Eq Dims
Tue, May 1, 2012 at 2:33:21 PM
11
Dims
Tue, Jul 10, 2012 at 4:41:31 PM
Using 2d group for Wall section, section details called out from wall section?
Fri, Oct 9, 2015 at 10:50:57 AM
The option to create Wall section not showing up, only building section.
Wed, Jan 23, 2013 at 3:16:47 PM
Page generation time: 0.8624
