44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Line Based Template File 9.1
10 Posts No Rating |
Hey everyone, I am looking for a "line based" template file to create detail components that is compatible with 9.1. The only one that I can find is for the 2008 version of the program. Does anyone know where i can Download it from, or is there a workaround for this. Ryan
![JAMESHGRIMES Avatar](user_avatar/17328.jpg)
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
Here is one
thnk you. but for some reason when I create a detail component, using that file, and insert into a project i recieve a "fatal error" message and the program has to terminate.....not so good ![Sad](/images/smiles/sadley.gif)
does anyone have standard detail component template , not line based
Not sure why you are getting an error. I tested the template on my computer and it worked fine. Do you have the latest build of the Revit Building 9.1 on your computer. There was supposedly a fix for corrupted template files on that build. Other than that I am not sure. Somebody else might be able to shed some light on the issue. Sorry.
3D line based hosted family template or solution |
Sat, May 2, 2009 at 1:46:17 PM
Is it possible to make a line-based family wall based? |
Wed, Jan 5, 2011 at 1:00:21 PM
Save an existing project file as a template file |
Mon, Oct 26, 2009 at 1:11:47 PM
Family Typical Model based on line |
Mon, Dec 22, 2008 at 7:55:47 AM
face-based lighting fixture families questions [ 1 2 ] |
Fri, Oct 24, 2008 at 12:17:51 PM
15
Members: | 2017495 | Objects: | 22947 | Forum Posts: | 152208 | Job Listings: | 3 |
