36 Users Online (35 Members):
Forums >> Revit Structure >> Technical Support >> TROUBLE INSERTING VIEWS
2 Posts No Rating |
i am using drafting views for my sections on this particular and there is 11 different files they we are using the same setions for and when i insert views from one revit file to another i can not get my sheet views for my details when i did this before on a different project with the same layout with different files using the same sections i was able to pull in drafting views and sheets all with these files i am using now i am not able to do that and i am using the same project file for my sections i used before
2 Posts No Rating |
sorry not on crack just did not even look back over and try any grammer on last post here is a little better i am using drafting views for my sections on this particular project. there is 11 different files that we are using the same setions for and when i insert 2d views from one revit file to another i can not get my sheet views. when i did this before on a different project using the same method using the same file to pull views from i was able to pull in sheets. i just need to know if there is a setting to keep from pulling in sheet views.
Error when inserting views from a Revit file (version 2011). |
Mon, Nov 29, 2010 at 1:22:24 PM
Inserting Views on a sheet |
Fri, Feb 26, 2010 at 3:18:37 PM
Elevation Views from a separate project |
Fri, Jul 10, 2015 at 8:01:44 AM
Fence |
Tue, May 2, 2006 at 1:21:59 PM
Cabinets only are inserting dashed |
Tue, Oct 26, 2010 at 10:25:29 AM
Members: | 2017980 | Objects: | 22948 | Forum Posts: | 152217 | Job Listings: | 3 |
