78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Tolerances
Thu, Jan 10, 2008 at 7:50:41 AM | Tolerances
42willh
Hello all,
This is probably something of an advanced question:
I'm working on a building curved only in plan (extruded 12 stories high-residential) in the shape of a boomerang, or heart.
I've been using circles to construct the geometry, beginning with grid's and/or reference planes/lines.
Getting the tangents to line up smoothly (accurately) has been something of a challenge.
I began with a 30-60-90 triangle (combine two for the rectangles seen in the attached image)  At the points of the rectangle I locate the circles and then sized accordingly to intersect.  THIS is where the problem begins.  A 30-60-90 triangle has a hypotenuse of square root 3 which is 1.732........ about 10 decimal places, Revit only goes to 3.
My point is, there seems to be slight inaccuracies caused by this rounding difference and when I go to trim sketched lines, this difference becomes apparent.
Now, if I use a 3-4-5 triangle, with angles 36.86 and 53.13, I get "simpler" whole numbers that are completely accurate according to Revit.
However, The 3-4-5 triangle relationship is too "squashed" of a look for this building, it needs to be closer to 30-60-90.
 This is the first curved project I've done and I was wondering if anyone could lend some advice or direction to topics/papers/studies, really any kind of information concerning curved geometry in revit.  And/or advice on alternate ways to construct something like this that is accurate.
Thanks
will
Mon, Jan 21, 2008 at 12:45:13 AM | Tolerances
nortoncad
nortoncad Avatar
Hi,
Tollerances can be adjusted in the Settings>Project units. Just select the length button, then change the rounding to custom, and give the preferred amount of decimal places.
In complex shapes like curved forms, that perhaps twist as they elevate, or interfear with other shapes, and produce imposible shapes, I find that the best way is to use building massing tools. Refer to the F1 help for details.
Hopfully this answers your questions.
Regards,
Mark Norton
Architectural Design Manager/Application Specialist for Revit & AutoCAD/Effective Project Crisis Managment/3D CAD modeling
Mon, Jan 21, 2008 at 7:12:02 PM | Tolerances
sciolist
That setting is not global, though.
One thing I find very frustrating is that the Tape Measure tool displays in 256's no matter how far in/out I am zoomed. Is there a way to adjust tolerancing there?
Mon, Jan 21, 2008 at 8:21:02 PM | Tolerances
NKramer
4 Stars: 9 Votes
The setting is global if you change your project units and your dimension styles are set to project units. You can change individual dim styles to vary from the project units, but by default everything refers to the project units.
As for the tape measure I dont know. I would imagine its in there somewhere. Typically I just end up actually dimensioning the item. Most of the time if you need to know what the dimension is so will the contractor.
Nick
Unit Tolerances
Tue, Aug 16, 2011 at 3:30:24 PM
Dimension String Doesn't Equal Overall Dimension
Mon, Jun 30, 2008 at 9:41:33 AM
Dimensioning tolerances to use align dimension with grid lines ?
Tue, Feb 9, 2016 at 11:18:30 AM
Dealing with tolerances....
Fri, Nov 15, 2013 at 9:39:30 AM
MARKETING DIMENSIONS
Thu, Jan 15, 2015 at 8:05:08 AM
Page generation time: 0.1910
