85 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Managing large projects in Revit? Site with multiple units/buildings.
Wed, Jan 9, 2008 at 6:20:50 PM | Managing large projects in Revit? Site with multiple units/buildings.
Robb
I would like to know if it is possible for Revit to manage large projects from seperate files?
We have a project with several buildings on the site. Each building has several floors/levels made up of multiple mixed units. I am thinking the project is too large to be managed in one file so we plan to draw each room unit as its own revit file then link/import the units into a seperate revit file to make up each building. This would be similar to how we would do it in AutoCAD with external references. I don't know if this the proper method but thats how I am thinking of doing this.
My questions is, if done this way, is it possible for Revit to keep track of the families used in the entire project and synchronize doors/windows/schedules/etc and have entire project update normally as if it were created in a single file even if the project is split into multiple files?
Am I on track or is there other methods or handling large projects?
TIA
Edited on: Wed, Jan 9, 2008 at 7:05:24 PM
Edited on: Wed, Jan 9, 2008 at 7:43:29 PM
Primary: Revit Architecture 2008\AutoCAD 2007Old Versions: Revit 9.1\AutoCAD 2002
Wed, Jan 9, 2008 at 7:53:32 PM | Managing large projects in Revit? Site with multiple units/buildings.
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You concepts are correct.
 Here is some info from my talk at the Revit Technology Conference 2007:
  1.
    • In Revit 2008 Groups and links are now interchangeable.  They can be bound or saved out at any time making this decision a little less critical.  The following outlines some of the benefits and limitations of both:
                                                              i.      Groups
1.      Can be tagged and quickly manipulated in the host file.
2.      Can interact (to an extent) with surrounding geometry not part of the group.
3.      Can exclude elements from specific instances of a group.
                                                            ii.      Links
1.      Better for file size as all information is stored in the other file.
2.      Tags have to be applied in the other file and the view linked across (not possible for sections & elevations)
3.      Somewhat more reliable as they do not need to interact with elements in the host file.
 Generally with large files (large is very ambiguous BTW).
So you links are going to be quicker to move and change, but more difficult to co-ordinate changes...
Once you go to DD/CD stage how you document will greatly depend on whether you use groups or links.  I try to keep 1 site file, 1 file for each building and the units as groups (which can be saved out and used in other files also).
HTH.
Regards,
Chris.
At what stage do you know when it's time to break up a model?
Tue, Dec 13, 2011 at 6:08:59 AM
Multiple buildings on one site
Wed, Feb 4, 2009 at 6:52:05 PM
Multiple units on sloping site
Tue, Feb 21, 2006 at 3:29:30 PM
Linking buildings to a site
Thu, Sep 16, 2010 at 4:28:49 PM
Topography over multiple phases.
Tue, Jul 22, 2014 at 5:10:34 AM
Page generation time: 1.8011
