72 Users Online (71 Members):
Forums >> Community >> The Studio >> Visibility frustrations
25 Posts No Rating |
I am experiencing frustrations with component visibility.
Seems most standard components have plan visibility off and rely on
symbolic lines to represent the casework, furniture, equipment etc.
All well and good until you put down a floor with a surface pattern and then
all components have pattern running through. Does anybody know and easy way
to fix this without editing every individual component to show plan visibility and then
reloading all back into my project...
Maybe I should gripe to autodesk. Seems like using symbolic lines in creating components is just the default process and not much thought is being given to the reality of what if will look like in a real project.
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
I found that a little irritating also when creating marketing plans...
i don't believe symbolic lines show ever be used to represent a family in plan on their own... you should use either a detail component that contains a filled region to block the unwanted section of floor surface pattern. Or if the model isn't overly complicated just have the 3D objects visible in plan?
Sometimes i think the revit content is created very quickly as an after thought... That's if i didn't know different.
Whaddup Newbie |
Wed, Jul 30, 2008 at 6:12:52 PM
Autocad frustrations. |
Thu, Oct 4, 2012 at 12:48:35 PM
Visibility Problem - please help!!! |
Fri, Jan 11, 2008 at 10:20:02 AM
imported DWG visibility |
Fri, Apr 13, 2007 at 12:26:22 AM
VISIBILITY |
Mon, Aug 7, 2006 at 5:36:38 PM
Members: | 2017196 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
