60 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Pattern Types...
Wed, Jan 9, 2008 at 1:25:02 PM | Pattern Types...
Quantifier
Quantifier Avatar
3 Stars: 2 Votes
Hi All,
 I created a wall with a surface pattern using a "drafting" types instead of "model" types. I'm able to view the pattern perpectly on the "default 3D view" but i'm having hard time viewing it correctly on camera view (perspective). The surface pattern are showing as if it is a solid fill. Does any of you have this issue before? What's the diffence between "drafting" and "model" pattern types anyway?
 Thanks in advance!
Wed, Jan 9, 2008 at 1:31:31 PM | Pattern Types...
LIZARD2806
3.5 Stars: 7 Votes
If you want to see the pattern properly in your model, you want a model pattern.  The differnce is that a model patterns are scaled with the model such that their scale will change based on the scale of the view.  A drafting pattern will always be the same size, as its scale is "fixed with respect to the drawing sheet".  There is a very good explanation in the help file of Revit.  Search for "fill patterns".
**Using Revit Architecture 2009, 2011, and 2012**
Wed, Jan 16, 2008 at 1:14:09 AM | Pattern Types...
IDN101
2.5 Stars: 3 Votes
http://www.revitzone.com/index.php?option=com_content&task=view&id=585&Itemid=45
Regards,
Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Floor patterns diff directions same pattern.
Sun, Sep 27, 2009 at 4:57:10 PM
Fill Pattern requirements
Mon, Apr 10, 2006 at 10:41:10 AM
Floor pattern not showing up when the pattern is model pattern
Fri, Nov 3, 2023 at 9:12:00 PM
create a custom fill pattern [ 1 2 ]
Mon, Jun 28, 2021 at 2:32:52 PM
29
Model pattern override
Wed, Nov 10, 2010 at 3:50:55 PM
Page generation time: 0.6391
