34 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> flat roofs
Wed, Mar 2, 2005 at 11:54:19 AM | flat roofs
ridhs
im doing a house with a flat concrete roof.. the way i drew was i selected roof by footprint and then changed the slop to be 0degs.. the problem though is that i cant see the roof line in plan.. and its really annoying if i wanna make any changes to it... also.. if i wanna but in a skylight wats the best way to do it? im sorry for all these questions.. im new at this ... thanx!
Wed, Mar 2, 2005 at 1:36:21 PM | RE: flat roofs
arnosandoval
5 Stars: 3 Votes
If you hold the tab key down you can tab thru your componets to get the roof. I think that should help with what you are trying to do. You could also use the filter command to filter thru selected items. With flat roofs yeah that's tricky. If you look in the family explorer you should find a skylight family already loaded. You can then change the family to meet the requirements for your project. Let me know if this helps.
Wed, Mar 2, 2005 at 5:24:25 PM | RE: flat roofs
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You don't draw a flat roof by setting the slope of the line in the sketch to 0. Select the lines and make them all non-slope defining by unticking the slope defining check box.
Thu, Mar 3, 2005 at 8:33:13 AM | RE: flat roofs
arnosandoval
5 Stars: 3 Votes
Mr. Spot is right about that. You set all your lines to No Define Slope, that might be one of the problems you might be having with the selection of the roof. Try that out.
Thu, Mar 3, 2005 at 12:38:55 PM | RE: flat roofs
TomDorner
4.5 Stars: 25 Votes
You can also select objects in a 3D view, elevation or secton then switch to a plan view to edit them. Tom
Sat, Mar 5, 2005 at 6:31:28 AM | RE: flat roofs
ridhs
thanx.. i didnt realize u cld turn the slope off.. but i still have one problem.. i dont know if its the way im doing it or what.. but the way i make the 3d model is that i make the floor and roof 30cms below the floor level.. but when i do this it disappears from my plan and the only way i can select it is thru the 3d view, which can be abooying all the time... wat am i doing wrong?
Mon, Mar 7, 2005 at 8:38:24 AM | RE: flat roofs
arnosandoval
5 Stars: 3 Votes
That's because the view range stops at the floor level. If you change your view range(under view properties) to just below you will see your floor and be able to select it.
Revit 2008 Multiple Roofs on Same level?
Tue, Jul 24, 2007 at 9:05:38 AM
12
Flat Roofs
Wed, May 28, 2008 at 5:24:52 AM
flat roofs - best practices
Mon, Jan 5, 2009 at 11:10:29 AM
Vallys in flat roofs?
Wed, Aug 2, 2006 at 2:37:27 PM
flat roofs
Wed, Feb 1, 2006 at 3:15:52 PM
Page generation time: 0.2732
