90 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Solid Fill Pattern
Mon, Jan 7, 2008 at 11:47:10 PM | Solid Fill Pattern
dvokic
Maybe someone can help me - I'm trying to use a Solid Fill Pattern for my New Construction Phase, but can't figure out how to have the walls show up at 60% or 80%, or for that matter anything less than 100% black.  Is there a way to have a gray fill pattern?  The SOLID fill is not editable, unlike the others.  Thanks much.
Tue, Jan 8, 2008 at 7:07:14 AM | Solid Fill Pattern
latemore
latemore Avatar
3 Stars: 2 Votes
not sure i understand this question, but filled regions have a lot of options, maybe investigate it further.  but it sounds like you might be wanting to control whole aspects of parts of the view.  i suggest you look hard at phase filters and their over rides, plus object styles, both globally and by view.  help is really helpful - search on these topics and you might find your answer.
Tue, Jan 8, 2008 at 11:56:26 AM | Solid Fill Pattern
dvokic
Thanks for the reply.
This question doesn't concern Filled Fegions specifically: regardless of whether it's a Filled Region or a Phase Graphic Override, for any FILL PATTERN the SOLID option is not editable.  It comes out solid black.  That's a nice option and I use it a lot.  However, what I am looking to do is make the fill pattern on the walls be gray, or as AutoCAD puts it 80% Shade (or 20%, or 40%, etc.).  So I tried using a regular, editable pattern - like CROSSHATCH - with a tighter spacing of the pattern.  Unfortunately this doesn't print, coming out just plain white.
It looks like there needs to be a new Pattern created for a Gray SOLID, and I wondered if anyone had anything like that already.  Maybe I need to post to the Wishlist forum.  Because it's not possible to edit the original SOLID, I wonder if the only way to get it is thru AutoDesk.
Thanks again for any help.
Tue, Jan 8, 2008 at 12:03:44 PM | Solid Fill Pattern
dvokic
I had just posted the message above when I turned back to the problem and solved it.  I missed something obvious.  It's really easy - all i had to do was change the color of the Fill.
It is so easy that I am embarrased.
Thanks.  Hopefully this posting will help others.
Wed, Jan 9, 2008 at 1:55:25 AM | Solid Fill Pattern
latemore
latemore Avatar
3 Stars: 2 Votes
so glad you worked it out.  i should have suggested the colour option, but i figured you had tried that!  revit has depths within depths, and it can be frustrating sometimes.  your post will definitely help others.
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:02 PM
Lost Solid Fill Pattern
Wed, Apr 9, 2008 at 7:58:48 AM
Revit 2015 Solid Cut Fill Pattern
Thu, Sep 22, 2016 at 8:27:55 AM
Solid Fill Hatch
Sun, Apr 1, 2007 at 8:56:32 PM
Fill Pattern
Mon, Jun 5, 2006 at 8:13:22 PM
Page generation time: 0.5607
