89 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> rendering trees libaray
Mon, Jan 7, 2008 at 11:27:29 AM | rendering trees libaray
superelboogie
Hi there...
So I am rendering a bird's eye view with lovely revit trees. I keep going to render and some of my trees dont render and just disappear. So I am having to reopen my revit session and/or reboot to get them to show up. I think that the problem is becasue our material libraries are on our network server and its pretty overloaded. Is there a way to keep my main materials libary on the server but have the tree library on my own computer. I am the only one who does trees. Where is the tree library originally located when you load revit to your computer?
Any advice would be greatly appreciated!
Mon, Jan 7, 2008 at 11:38:30 PM | rendering trees libaray
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Ahh, the plant library has a file extension of plib.  Similar the material library has an extension of mlib...  However, it will depend on the actual individual plants as to where there bmps, jpgs and alphas etc are located.  Seems like a strange issue though if it works sometimes and not others.
Regards,
Chris.
Tue, Jan 8, 2008 at 9:14:22 AM | rendering trees libaray
superelboogie
It really is the weirdest thing. Because I will do a test renders and move things around and go to render again and then half my trees dont render the second time. If I reload my revit seccion or sometime even reboot then they will work for a couple more renders. It could make a person loony!
Wed, Jan 9, 2008 at 8:14:28 PM | rendering trees libaray
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Sounds like it could be a Virtual Memory issue on your machine.  Ensure you have the 3Gig switch enabled and your page file size set to a fixed amount.
Also, there are programs out there that free up your RAM/VM from memory hogs such as revit - mind you I haven't had any real success with this method.  When rendering it uses a lot of memory...
HTH.
Regards,
Chris.
rendering trees in winter???
Tue, Dec 14, 2010 at 5:46:54 AM
Rendering Trees in Revit 2010
Wed, Apr 27, 2011 at 2:53:38 PM
Revit 2012 problem rendering RPC trees
Tue, Sep 6, 2011 at 5:26:08 AM
Rendering Trees
Mon, Mar 19, 2007 at 7:15:33 PM
Rendering Trees/Searching
Fri, Jun 17, 2011 at 2:49:31 PM
Page generation time: 0.4802
