70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Sheet 01 of 20; can I make this label?
Mon, Jan 7, 2008 at 8:44:13 AM | Sheet 01 of 20; can I make this label?
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
Hi, my boos want to use this method, I made manually but man it's revit. how to do it?
Mon, Jan 7, 2008 at 11:29:35 PM | Sheet 01 of 20; can I make this label?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Unfortunately as of yet there is not parameter that can automatically calculate how many sheets there are in the set and as such it has to be entered manually...
It would be possible to create a tool that does this using the API.
Regards,
Chris.
Tue, Jan 8, 2008 at 4:27:10 PM | Sheet 01 of 20; can I make this label?
ebtaylor
3 Stars: 2 Votes
This is a workaround I use since I can't get what you are asking.
This is possible with shared parameters from your title block. I have shared parameters for total sheets (as a type) and another for drawing order (as an instance). The drawing order parameter is shared so I can use it in my drawing list for sorting and for "sheet 01" on my title blocks. This way I get "DWG  2  of  53". The total sheets parameter is setup under my project info, so once I know my total sheet count I set it there and it updates all my sheets.
hope this helps
Dependent Date-Label
Mon, May 13, 2013 at 2:23:05 AM
Sheet Label to Drawing List
Fri, Sep 9, 2011 at 2:56:27 PM
Title sheet label
Wed, May 7, 2008 at 12:17:42 PM
Titleblock label editing
Fri, Mar 30, 2012 at 6:56:26 PM
Revit 2009: Custom label in title view & Reference sheet
Mon, Dec 8, 2008 at 7:09:24 PM
Page generation time: 0.8861
