37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Cad links
Sun, Jan 6, 2008 at 2:26:43 PM | Cad links
Kiarash
Hello everyone
I am a new member and our office is going to go Revit and suppose to help them, I self training myself. I started with a midrise project, created the model by linking Cad drawings, and later on instead of unloading links I deleted them, and then I made that a central file. Now if I go to " manage Links " I see list of Cad files which I can't get rid of. If I try to remove them Program says "Can't edit the element, it was deleted in the central file". Does anyone have any suggestion. Thanks
Sun, Jan 6, 2008 at 2:59:16 PM | Cad links
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If it was deleted in the central file then it sounds like the file your using just needs to catch up... Have you tried doing a save to central?  As soon as all instances of a link are deleted from a project they should automatically purge themselves from the manage links section...
HTH.
Regards,
Chris.
Can I set CAD links to default to the foreground?
Thu, Jun 23, 2016 at 4:58:32 PM
Dimensioning to CAD links in Revit - Dims deleted
Wed, Aug 7, 2013 at 2:39:02 PM
Auto Reloading CAD links on Project Startup?
Thu, May 8, 2014 at 2:56:54 PM
Exporting 3d cad formats with links
Fri, Mar 27, 2009 at 2:42:36 PM
Xrefs in CAD links
Fri, Sep 25, 2009 at 12:22:44 PM
Page generation time: 0.3406
