100 Users Online (98 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Counter top
Sat, Jan 5, 2008 at 7:03:28 PM | Counter top
askask
i want to put in a granite counter top to a revit residential project. The problem is that it does not look like granite. Is there any way that i can put a jpeg image (or a different format) on to the counter top to make it look real? Thanks
Mon, Jan 7, 2008 at 9:00:44 AM | Counter top
UserError
UserError Avatar
3 Stars: 1 Votes
You can import image files. File, Import/Link, Image and place it into your model where needed.
Mon, Jan 7, 2008 at 1:05:48 PM | Counter top
askask,
You only need to assign the countertop material to an accurender bitmap.  If your material is set to default, open the family and re-assign it there.
Counter Top question
Tue, May 24, 2005 at 8:46:44 PM
counter top model
Mon, Feb 28, 2011 at 2:11:17 PM
Sink not visable when using counter top family
Mon, Aug 27, 2007 at 10:11:14 AM
Custom Counter Top Profiles
Thu, Jan 11, 2007 at 7:59:57 PM
11
Totaling Length of Counter Top used
Fri, Mar 16, 2007 at 2:54:45 PM
Page generation time: 2.0635
