186 Users Online (185 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> How reduce size of BNIM Freight House Flats file?
Sat, Jan 5, 2008 at 1:40:35 PM | How reduce size of BNIM Freight House Flats file?
revitlearner
SINCE NO ONE WILL PROVIDE A SAMPLE HIGH-RISE FILE, I am using the BNIM Freighthouse file provided with my version of Revit.  It is a wonderful project, but  I am only practicing and doing renderings in one apartment, and the file is 82 MB.  When I delete portions of the building the file seems to only get larger.  I really only want the pieces concerned with this one apartment to remain, but I don't want to use a section box as I've found that causes other problems.  Any help?   Thank you.
Sat, Jan 5, 2008 at 6:04:30 PM | How reduce size of BNIM Freight House Flats file?
geofm
hello revit learner.
why dont you do a save as and work on the copy , then you will still have the original untouched.
alter the copy ( delete all floors, elevations sections etc that dont apply, except for the 1 apartment you are working on.)  you could do a purge unused, that should also reduce file size.
it wont matter if u stuff it up as you will still have the original ( because you made a copy).
cheers
geoffm
Thu, Apr 16, 2009 at 4:50:11 AM | How reduce size of BNIM Freight House Flats file?
flynakashima
hi, anyone has the BNIM freight house file? would u mind sharing it?
Wed, May 27, 2009 at 2:59:31 PM | How reduce size of BNIM Freight House Flats file?
luther81
i can get a copy of the bnim frieght house project file lnlampkin@gmail.com
looking for BNIM freighthouse flats file
Tue, Oct 27, 2015 at 7:28:20 PM
how to reduce size of file for archiving
Tue, Oct 24, 2006 at 2:35:53 PM
Revit 2010 - How do I reduce file size?
Wed, Mar 16, 2011 at 10:19:33 AM
When you save as your file. File size reduce automaticly
Fri, Dec 16, 2011 at 9:36:48 AM
reducing file size
Wed, Oct 11, 2006 at 4:01:49 PM
Page generation time: 0.9709
