74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> CAD exporting RE:What is an ACIS solid
Fri, Jan 4, 2008 at 1:41:02 PM | CAD exporting RE:What is an ACIS solid
UserError
UserError Avatar
3 Stars: 1 Votes
One of the export options in Revit (I am using 2008 version) is that I can export a *.dwg as an ACIS solid. What exactly is an ACIS solid and how is it different from a polymesh?
Fri, Jan 4, 2008 at 4:22:44 PM | CAD exporting RE:What is an ACIS solid
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
ACIS solids are objects that AutoCad uses. The have volume and mass. Polymesh objects are made up of 3D FACES to represent the solid object. They do not retain volume information. When you are modeling in autocad you create solids by using tools like extrude, revolve, sweep..etc. with closed polyline profiles. If you look in the Revit help under Export Options you should find a detailed description of the two options. HTH
ACIS Import
Thu, Jan 26, 2006 at 11:53:33 AM
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
Fri, Oct 12, 2012 at 7:31:59 AM
Solid Body Text for File Export
Wed, Sep 14, 2016 at 9:34:34 AM
Exporting to CAD from Revit 2012
Mon, Oct 8, 2012 at 7:30:50 AM
ACIS export problem and Hi from France
Mon, May 30, 2011 at 10:10:05 AM
Page generation time: 0.9127
