40 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Interoperability
Fri, Jan 4, 2008 at 11:54:42 AM | Interoperability
j100
My firm is looking to begin working with consultants also using BIM.
<> We're new to this process and I'm curious as to whether or not the model will be "frozen" in the Structural and Mechanical versions of Revit.  Does anyone know if they can manipulate the architectural model elements we created, or if it behaves more like a "background" that they can only add information into?
<>blame the monkeys,
<>j100
Fri, Jan 4, 2008 at 4:25:13 PM | Interoperability
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
With the file linked into another model it cant be modified beyond Visibility and Graphics. This, however, does not prevent anyone from opening the model and modifying it from there.
Fri, Jan 11, 2008 at 1:35:46 PM | Interoperability
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Hello j100,
I'll see if I can shed some light on this subject for you.
The way the Revit disciplines can work together is using a process called copy/monitor.
The way this process works is when the architectural firm is ready to start working with the consultants, they will send over a copy of their central file to the structural and mep. What they do is then take the architectural model and link it into their file. Now that it is linked, it will act as a background for theirs. What should be done from their aside from some set up is start the copy monitor process. What happens is they will go through the architectural model and copy certain aspects into their Revit structures file, hence the copy part of the name. After that happens, Revit will begin monitoring all the objects that they just copied into their file, thus the monitor. The monitor aspect will compare the two files and it will notify them of any changes  that have been made to the monitored object from the architectural file.(i.e...if a grid moves in the architectural file, when the structural load the latest file, they will be notified.)
So what happens is all the disciplines will actually develop their own file using each other as a background. Now as James said, they can open the architectural file, modify it and then update the structural file and then send it back to the architects, but there is a little bit of checks and balances here. Although I did work with one client that insisted on developing the entire project in one file, but that DEFFINATELY NOT the way to go. Way to much information inside of one file.
As they are copy/monitoring your file, you are to theirs so if they make changes to applicable objects you will be notified as well. And with that notification comes the ability to deny, accept, postpone the changes giving each a little more control of what is happening.
Now copy/monitor will not allow any discipline to copy the entire project, it will only let certain objects be copied.
So will still use their files as a background and have to make some changes visually.
So long winded explanation. All the Revit disciplines will (should) develop their own separate file.
HTH
Brett
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Tue, Jan 15, 2008 at 4:36:28 PM | Interoperability
j100
Thanks guys -  You've been most helpful!
<>j100
Autocad frustrations.
Wed, May 9, 2012 at 8:07:23 AM
AutoCAD - Revit - 3D Interoperability
Tue, Mar 25, 2014 at 3:38:51 PM
problems with Revit 2013 in 3ds Max!
Fri, Dec 14, 2012 at 12:14:10 AM
Revit 2009 corrupted files
Thu, May 1, 2008 at 10:26:23 AM
Placing Lighting Fixtures in Revit Systems
Wed, Nov 15, 2006 at 7:59:29 AM
Page generation time: 0.2309
