72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> corner windows
Wed, Mar 2, 2005 at 12:05:50 AM | corner windows
ridhs
hi.. again.. im trying to do a corner window and have spent almost a day trying to get it rite. i tried to use a window and put it in the corner and overlapped another window with it so both their mullions are at the corner. but i still see a little piece of wall. how can i get a clean and realistic corner window? thanx
Wed, Mar 2, 2005 at 12:17:21 AM | RE: corner windows
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Checkout my fixed gl@ss corner window in the family explorer i uploaded a while back. Can't remember if its the latest incarnation but you can adjust for various corner angles, wall thicknesses and also adjust frame thickness and leg lengths. Trust this is helpful. If you can't find it let me know.
Wed, Mar 2, 2005 at 1:03:01 AM | RE: corner windows
ridhs
THANX.. it helps... but is this the only way to do it? cuz mostly i have 90deg angles..
Wed, Mar 2, 2005 at 1:42:58 AM | RE: corner windows
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Well no its not the only way of doing it, but the advantage of this window is that its one family for instances and a simply matter of changing the type in the project and setting it to 90�...
Sun, Mar 13, 2005 at 12:28:53 AM | RE: corner windows
ridhs
thanx the corner window helped... but i have a question if im using curtain walls which are embedded into the wall how can i clean up the corners so that the wall doesnt show? what if its frameless glcurseand i dont wanna put a mullion on the corner?
Tue, Jun 3, 2008 at 10:56:06 AM | corner windows
thankyoufrankgehry
1 Stars: 1 Votes
Mr. Spot--
How do you go about altering the wall to make it a 90 deg. opening.  I am able to change the window itself, but not the wall.
Thanks.
ac
Corner windows with variable angle
Tue, Dec 27, 2016 at 4:47:10 PM
Corner windows
Thu, Apr 10, 2008 at 9:14:45 AM
Corner Windows
Fri, Sep 11, 2015 at 11:03:10 AM
Corner Windows
Sun, Feb 25, 2018 at 6:27:00 AM
Corner windows
Tue, Aug 2, 2005 at 1:51:34 PM
Page generation time: 0.4972
