53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Blending + Revolve + Sweep.
Thu, Jan 3, 2008 at 10:58:49 PM | Blending + Revolve + Sweep.
tchuparkoff
Does anybody have any experience combining multiples to create a complex shape. I am in desperate need of help creating a roof stucture that in my head should be a blend around a curve. Is this possible and if so please advise quickly.
 Thanks in advance,
Thomas
Tue, Jan 8, 2008 at 12:03:56 PM | Blending + Revolve + Sweep.
mthurnauer
3 Stars: 2 Votes
Could you post a sketch of what you need to create?  You can only blend two profiles.  If you need to blend more than that, you need to do it in a series. For example: blend from profile 1>2, Blend from 2>3, 3>4, etc.
Tue, Jan 8, 2008 at 8:48:40 PM | Blending + Revolve + Sweep.
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Remember you can import nurbs forms from Rhino or other 3D apps in DWG or SAT formats into a mass file and use that to generate your revit roof...
Regards,
Chris.
blending a sweep (Modeling)
Fri, Dec 16, 2011 at 2:37:56 PM
Revolve Axis
Wed, Mar 29, 2006 at 2:46:10 AM
How to model Sweep/ Blend/ Revolve in family
Thu, Oct 3, 2013 at 7:41:26 AM
blending curves
Mon, Oct 13, 2008 at 12:22:38 PM
using revolve tool to shape top of walls 'Revit 2012'
Wed, Feb 20, 2013 at 2:47:55 PM
Page generation time: 0.8311
