Forums >> Community >> Newbies >> Getting started
1 Posts No Rating |
I have been using autocad since 1983, 25 years, and I'm brand new to Revit. I am learning on my own without classes, so far. I have read and tried to follow 2 Sybex books: Introducing Revit architecture 2008 & Mastering Revit Architecture 2008. Both were disappointing. I was able to complete a small project and I was impressed with the potential of Revit. I hopw I can get answers here and to some basic questions. My first question: Is it possible to show window tags in elevation views?
Yes, just go to the Drafting Tab, select 'Tag by Category'. and hover your mouse over the window. You will have to have the window tag loaded in the project, but otherwise you should be able to show the tag in elevation/section.
you can also tag them all at once using "tag all not tagged"
Any modelled element can be tagged in any view (with the exception of 3D views). Welcome to Revit. Be prepared to forget all that Acad stuff, it will just hold you Revit learning back
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
1 Posts No Rating |
Getting Started
Edited on: Mon, Mar 24, 2008 at 10:06:22 AM
Revit File at 20% and it HASNT Started Rendering Yet?!?! |
Sat, Apr 30, 2011 at 5:42:55 AM
Need Help Getting Started |
Tue, May 3, 2011 at 8:40:03 PM
Getting Started with the project and inserting Elevators |
Fri, Aug 26, 2011 at 7:52:13 AM
Getting started with Revit 2015 |
Thu, Nov 6, 2014 at 7:55:16 AM
Newbie has started using Revit for 2 weeks, advise need... |
Mon, Feb 8, 2010 at 10:44:08 AM
Members: | 2104993 | Objects: | 23178 | Forum Posts: | 152306 | Job Listings: | 3 |
